I have a hosted feature layer view that contains three layers and three related tables. I've created a web map from this hosted feature layer and configured the Search options on the web map (settings tab) to do a contains search against the relevant fields of each of the map layers and one of the related tables:
However, in the map, the search function doesn't seem to work. The screen grab below shows the Buildings layer turned on and labelled with the 'name' attribute. There is a building called the 'David Attenborough Building', yet searching for 'david' or 'attenborough' doesn't return any results:
I get the same behaviour for the other two spatial layers ('Colleges' and 'Porters Lodges'). But the related table does work as expected and shows results from a 'contains' search, as shown below:
If I change the search settings of the three layers from Contains to Equals then I get better results:
Now when I search in the map against the 'Building' layer for 'david' it does indeed find the David Attenborough Building:
Furthermore, I'm able to use the % symbol as a wildcard so searching for '%atten' also finds the David Attenborough Building:
I'm pretty sure this used to work, so I'm wondering if something got broken in the most recent update to ArcGIS Online this week? The specific issues seem to be:
Am I missing anything or have I misunderstood how this is meant to work in Map Viewer? The documentation (https://doc.arcgis.com/en/arcgis-online/create-maps/configure-feature-search.htm) is pretty sparse and doesn't say much other than: 'Choose whether the result should contain or be equal to the search terms.'
Any help would be greatly appreciated.
Are you able to share your map and layers and I can take a look? You can drop them into a group and invite russell_jsapi into it. thanks!
Hey @RussRoberts, thanks for getting in touch. I've shared the map and layers with you, so hopefully you can see the issue. Any help would be greatly appreciated.
Do you see it working against the original FL instead of the view? I see the fulltext not working as expected on that view layer but just checked against some of mine and they were working.
