Chart Widget - ArcGIS Online
676
08-27-2017 10:54 PM
TankisoMabote
I am having a problem configuring the Chart Widget. I am only getting one option for “Chart Display” when I used to have 4 namely:
Display values feature by feature
Display values by category
Display feature counts by category
Display attribute values as charts
I am now only getting the 3rd option only. Display feature counts by category. How do I get the others to show?
Regards
Tankiso
by Anonymous User
Not applicable
Hi Tankiso, you may want to test you field type - are you using string or integer? This may affected how you will be able to chart your data.
by Anonymous User
Not applicable
TankisoMabote
Thanks Alix,
After changing field type to integer it worked like a charm
Regards
Tankiso
