Cannot Add Georisques WMS to a map in ArcGIS Online
759
11-15-2019 05:30 AM
ClémentLaskar
I'm trying to add the following WMS service to a map in ArcGIS Online :
https://georisques.gouv.fr/services?&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
The request is working in my browser.
In ArcGIS Online, I get the error "The service '' does not exist or is unavailable"
The URL is formatted just as in the exemple for adding similar data in Esri online documentation :
Ajouter des couches à des cartes—Portal for ArcGIS | ArcGIS Enterprise
Did anyone had the same issue with a WMS service ?
Clément
ClémentLaskar
This problem seems to be due to layers groups that are presents in the service. As mentionned in the page https://enterprise.arcgis.com/fr/portal/10.5/use/ogc.htm, those services are not supported.
bendeg
Instead of the URL you give, try this one :
http://geoservices.brgm.fr/risques
If it works, it means that you have to use a mmore specific URL given here :
https://infoterre.brgm.fr/page/geoservices-ogc
