Auto-populate unique ID field in hosted feature layer (common ID between copy/pasted features in ExB)
944
5
04-24-2026 06:45 AM
Bud
Legendary Contributor
In Experience Builder > editor widget, I am manually copying features from layer1 into layer2. Layer1 is a Survey123 hosted feature layer.
I want there to be a common ID between the two features so I can know what the layer1 source feature was for the layer2 destination feature.
Is there a way to auto-populate a unique ID field in layer1 in AGOL?
For example, is there a way to automatically populate a custom ID field in layer1 with the OBJECTIDs? My assumption is that OBJECTIDs can't be copy/pasted into new features, but values from a custom ID field can.
Related Experience Builder Idea: Field mapping for copying/pasting features using Editor widget
Katie_Clark
MVP Regular Contributor
Right now I have a similar use-case and I am using a scheduled Notebook to assign UUID's after a feature is created.
If there's a way to get this to automatically populate on creation I'd love to know!! But I wasn't able to find it in my initial research when I set this up a while back....fingers crossed maybe I just missed something and it's actually possible?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Bud
Neal_t_k
@Bud Since you mentioned Survey123 if you are using Connect, there is uuid() function you can use to populate a unique id
Also, there should be GlobalID in your Survey123 layer (layer1) already that you could copy to layer 2
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Bud
@Neal_t_k  Thanks for the info about Connect! I don't have experience with it. I will look into it.
I've wondered about this too. The ExB copy/paste functionality seems to copy/paste into fields that have exactly the same field name.
However, as far as I can tell, the destination feature gets a different/new GlobalID, not the GlobalID from the source feature. So I think I'm out of luck here.
I'm not aware of a way to "field map" the source GlobalID to a custom destination field like ORIGINAL_GLOBALID.  Experience Builder Idea: Field mapping for copying/pasting features using Editor widget
Bud
From a comment in Add GUID field to existing AGOL Survey123 feature layer — Field not auto-populating?
GUID fields don't autopopulate, they default to null.  They're typically up to the application or an editor to set.
You could make a hidden field in your S123 form for the question and use the uuid() function to populate it.
Alternatively, you can use the Admin REST API to create the field with a NEWID() default value, with the Add to Definition endpoint of the layer.  It may be possible to update an existing field's default value with this as well, but I haven't tried it.  This will make the field autopopulate with a new value in the same way that Global IDs are autopopulated:
  "fields":
      "name" : "MyID",
      "type" : "esriFieldTypeGUID",
      "alias" : "My ID",
      "sqlType" : "sqlTypeOther",
      "length" : 38,
      "nullable" : false,
      "editable" : false,
      "domain" : null,
      "defaultValue" : "NEWID() WITH VALUES"
