Assigning values to zipcodes only
667
01-26-2023 07:35 AM
FastandCurious
Hey there,
I am using ArcGis (agol) and am trying to color code zipcodes with a single value or statistic. I am having trouble applying the table data to the map. For example, Zipcode 12345 has a total of 100 sales, and zipcode 54321 has a total of 8000 sales. I want to apply the number of sales to each zipcode and then color coordinate.
Is this possible? I was told to figure this out without using credits.
Thank you in advance.
jcarlson
MVP Esteemed Contributor
Yes, it's definitely possible! Assigning symbology (color coordinating) based on a numeric attribute does not consume credits. It sounds like your sales data is separate from the ZIP areas, though? If so, performing an attribute-based join between the two layers would cost credits, and would be dependent on how many features are involved. But I wouldn't expect it to cost much. The analysis tools in AGOL should be able to give you an estimate before running it.
- Josh Carlson
Kendall County GIS
FastandCurious
Hey Josh,
Yes, for data points we just have the zip code only, there is a base map I am not able to alter or add data to unfortunately so I have to combine two layers. Is it possible to manually create a layer with everything by creating polygon shapes? For example:
