ArcGIS Web App not honouring Web Map Symbology!
8368
22
03-04-2023 06:51 PM
Marie-AngeFournier-Beck
I have 7 web apps and 7 different web maps (one for each app). All of a sudden, yesterday, one of the web maps started to not honour the symbology that was set in the web map. It was only with the polygon layers. The web app has started filling in 3 of the polygons feature services when all of the settings, including in the visualization settings of each feature service, has the polygons shown only with a black outline - no fill. I have deleted the map, recreated an entirely new map. Deleted the app and recreated an entirely new app. I have changed the basemap. I have removed the feature layers from the map then added them again... I still get the same error from the web application - where 3 polygon layers are shown filled in and not as just outlines.
EDIT: Now it is doing this for all polygons within my map and for all maps, but only in the web app builder, not in the map itself.  I hope someone has some advice out there!!?
RussRoberts
Esri Notable Contributor
Map Image Layers will not have the same advanced symbology case where its coming in. You would have to click on the feature layer options to change those properties for the feature layer case. In that case Pro would be publishing to the service case and not overwriting what is at the item level for a layer for symbology. This I believe is coming at 3.2 .
JaneMiller1
I was having the same issuing publishing from Web Viewer Classic so switched to Map Viewer (despite hating it), but as of today, my Web Apps are not honoring symbology I created in Map Viewer (not Classic). Let me know if anyone else is having this issue going forward.
RussRoberts
Would like to hear what issues you have with Map Viewer?  No recent changes have gone out this week. Can you share the map and give additional details on what the expected vs. actual results are?
Thanks!
