ArcGIS Online Web App Printing Widget issues?
7239
11
07-27-2018 04:25 AM
CSCompanies
Hello,
I am trying to get my layers that I have turned on to display on the printing widget but when it pdfs the layers that I display in the web app do not display on the pdf?  I don't have any developing skills so any help would be appreciated.  Thanks, WayneScreenshot from web app displaying a layer.Screenshot from pdf created with printing widget not displaying what was on my screen in the web app.
KellyGerrow
Esri Alum
Which layers aren't displaying in the print? Are they located in ArcGIS Online or hosted on an internal server?
-Kelly
CSCompanies
Hi Kelly,
Thanks for the response.  The colored layers in the first image are not showing.  The second image is the pdf I am getting in the print widget.  The layers are all on ArcGIS online.  I basically shared my ArcGIS Pro document with all the layers as a web map and then created the web app.  Thanks, Wayne
AndrewHansford
CS CompaniesKelly Gerrow
Hi Wayne,
We had the same issue here. We noted that it happened after the April update to AGOL. We got our local distributors/vendors to assist us as we found this behaviour very odd.
The solution was in your Map document (MXD or APRX)
  1. You need to ensure that all your layers are turned on.
  2. Set a reference scale of 1:1500 (unsure why).
  3. Republish the service.
  4. This step we took to ensure that it wasnt the WebMap causing the issues. we created a web map
  5. Then we updated the Web App.
Our distributors/vendors were going to raise a bug with ESRI.
Hope this helps.
Thanks
Andrew
CSCompanies
Thanks Andrew,
I will give this a shot and let you know if it works.  I appreciate your reply.
CSCompanies
That worked Andrew.  Thanks for the tip.
KellyGerrow
Esri Alum
Thanks Andrew,
Was a bug logged for this?
Do you have any sample services/web maps that are exhibiting the behaviour?
-Kelly
AndrewHansford
Hi Kelly Gerrow‌,
Yes our local distributor Eagle Technology were going to raise a bug
Thanks
Andrew
AndrewHansford
Hi Kelly Gerrow‌,
I could publish the dataset for you as it was and then send the link to you if you like?
Thanks
Andrew
diegocarvalho
Hi All,
Would you have any position from ESRI if this bug was solved? I still can't print my Feature Layers and does not seem reasonable for me to use workarounds to make this happen, when it should be solved already. Thanks!
