Arcade - Return Layer Name (AGOL)
6157
7
08-23-2019 02:16 AM
DavidFotheringham1
I am looking for a way to return the layer name (as seen in the table of contents) using Arcade in a popup in AGOL.
Reason - I have 60+ individual study areas and when a user clicks on one it would be nice to have the pop up tell them which one it is. Each study area only has 1 feature in it. The attributes do not, currently, contain the study area name.
Solution 1 - add a field for each study area and include the name for easy pop up
Solution 2 - find out if Arcade can do it already
I know solution 1 will work but I am more intrigued to understand Arcade better and see if this is a function exists!
XanderBakker
Esri Esteemed Contributor
Hi David Fotheringham ,
I was expecting to find a name property on the $layer object, but there doesn't seem to be one. I assume the optimal option would be to work with a single feature layer and the additional attribute to hold the study area for each feature.
You can use a python script to merge them together and add the additional attribute and publish the feature layer again.
XanderBakker
DavidFotheringham1
Thanks Xander Bakker‌. Glad it was not just me that could not find a 'name' property. I'll revert back just updating the layers with a 'name' field directly.
AlexNies2
David,
It is low tec but you can use Concatenate and just type out the layer name.
Example: Concatenate(['Layer Name',$feature.Label], ':')
dzahsh
GetFeatureSetInfo(GetFeatureSet($feature)).layerName
DanielKarkoszka
Thanks. This is the solution I needed!
cat206
Hi @dzahsh , do you by any chance know a way to get the layer alias rather than the name?
dzahsh
@cat206 This will return the custom Layer title as set in a Web Map :
GetFeatureSetInfo(GetFeatureSet($feature)).webMapLayerTitle
More info about different properties of FeatureSets :
https://developers.arcgis.com/arcade/function-reference/featureset_functions/#getfeaturesetinfo
