Arcade expression with 2 fields
1780
07-22-2020 01:05 PM
JenJoern
Was hoping to get help with an Arcade Calculator issue. I have two field names I am referencing and 4 possible outcomes to populate a new text field.
I have an integer field as well as a text field that is domain driven. The end result is a simple text return: (Pass, Fail, No Locate, Other).
If the number field = 1, and domain field = Full, then = Pass
If the number field = 1, and domain field = Dim, then = Fail... and so on.
Any Arcade wizards out there willing to help? I made a couple rough attempts, but am having trouble with referencing 2 different fields.
Thanks!
KenBuja
MVP Esteemed Contributor
One problem you might be running into is when you're using a domain, you have to either make your evaluation with its label or use DomainName to use its code.
For example if DomainField is set up like
LabelCode
1Full
2Dim
then you'd either use
if ($feature.DomainField == 1)
or
if (DomainName($feature,'DomainField') == 'Full')‍‍
For your calculator, one way of evaluating your two variable would look something like this
if ($feature.NumberField == 1) {
  if ($feature.DomainField == 1) ‍‍{ // if (DomainName($feature,'DomainField') == 'Full')‍‍
    return 'Pass';
  } else if (if ($feature.DomainField == 2) ‍‍ { //if (DomainName($feature,'DominField') == 'Dim')‍‍
    return 'Fail';
//etc‍‍‍‍‍‍‍‍
JenJoern
Thank you Ken Buja‌, got it to work.
