Arcade Expression For Selecting Future Dates
2938
9
02-11-2022 02:20 AM
Labels (2)
map16jamie
Hi there, does anyone have a method of filtering a layer that shows features containing a date field which are within the next 'x' days. I know that there is already a date filter which can filter features within the last 'x' days but not within the next.
For example the layer has a field containing future dates and I would like only features to be selected by this field if it is within x days of todays date.
IDFruitDate
1Apple13/02/2022
2Pear14/02/2022
Any help would be much appreciated
2 Solutions
HuubZwart
I don't think this is possible using the regular layer filter in the webmap, but you can tweak the definition expression for the required layer in the web map using ArcGIS Online Assistant (or update the web map via REST interface). You can use any supported SQL statement here such as
DateField BETWEEN CURRENT_DATE() AND CURRENT_DATE() + x
Be aware this makes it impossible to further edit the expression in the webmap interface, you will get an error there if you try to.
JohannesLindner
MVP Alum
Ah. In that case:
  • go to the layer's style settings
  • Choose "New Expression" as symbol field
  • edit and use this expression (it will return true or false):
var start_date = Today()
var end_date = DateAdd(Today(), 5, "days")
var test_date = $feature.DateField
return test_date >= start_date && test_date <= end_date
  •  Choose "Distinct Values" as styling option
  • Style the symbols for true and false
  • You can also hide the false features by setting the transparency to 100%.
 Before:
After applying the Arcade expression:
After hiding the false features:
Note that this approach will probably be slower than just filtering out the undesired features from the layer (see HuubZwart's answer).
Have a great day!
Johannes
JohannesLindner
MVP Alum
var start_date = Text(Today(), "Y-MM-DD")   // Today: 2022-02-11
var end_date = Text(DateAdd(Today(), 5, "days"), "Y-MM-DD")  // Today +5 days: 2022-02-16
var fs = FeatureSetBy*(...)
var future_records = Filter(fs, "DateField BETWEEN @start_date and @end_date")
Have a great day!
Johannes
map16jamie
Hi Johannes,
Thank you for your reply, I forgot to mention I was trying to do this in Mapviewer. I tried the expression above but the function 'Filter' cannot be used within the symbology.
JohannesLindner
MVP Alum
Ah. In that case:
 Before:
Have a great day!
Johannes
map16jamie
Thank you Johannes!
HuubZwart
map16jamie
Thank you HubbZwart, This has worked 🙂
map16jamie
Hi HuubZwart,
Thank you for this. Having tried this it works when viewing on Mapviewer but when trying to load this map on Field Maps it does not load the layer at all. Does this method work on Field Maps?
skunkpup
It helped me a lot. Thanks.
fireboy and watergirl
AudreyDawson
Loking for a while for this. Thanks        Lucky Days Casino
