Add Highway Symbols to AGOL with Arcade
1006
06-11-2020 11:36 AM
by Anonymous User
Not applicable
Are there examples for adding highway markers as labels in AGOL?
Thanks in advance,
Russell
XanderBakker
Esri Esteemed Contributor
Hi GibbyAR ,
Although not exactly what you are looking for (pop-up and not label), the example by Esri Netherlands is pretty cool:
Combining Arcade and HTML for a Real-life Pop-up Display
What exactly are you looking for?
by Anonymous User
Not applicable
Thanks, Xander.
Ideally, I’d like to use Arcade to define a symbol or label class to place shields on road features for both Interstates and US Highways. I see zero documentation for how to do this in AGOL.
r
XanderBakker
Hi Russell Gibson ,
For ArcGIS Pro there is a support article indicating how to create the label classes and apply the correct symbology: How To: Label highways with a shield marker containing the highway number in ArcGIS Pro .
In ArcGIS Online, this is a lot more restricted. In the current web map you cannot create label classes and labeling of lines is restricted to a text. The new (beta) web map does allow you to create label classes, but still you can only create a text for a line. You will need points (which will make it difficult to show the correct one depending the view scale and extent) and place a label on top of it. I don't see how it would be possible to do this correctly in ArcGIS Online.
Maybe there is a service in the Living Atlas that contains the highway shields that you can consume directly.
