Allow Admins to manage Offline Map Areas
5821
22
10-29-2019 12:45 PM
Status: Open
AaronKoelker
Our organization is large and has employee turnover, and often we need to transfer ArcGIS Online content from an employee who has left to somebody else. Also, with Enterprise accounts, we sometimes need to create a new account for someone due to email changes, and transfer over their existing content. When a web map is enabled for Collector and has Offline Map Areas created for it, admins are not able to transfer ownership of that web map (per ESRI documentation). They are also not able to view or manage those Offline Map Areas—including being able to delete them.
The only workaround we have found so far is to create a copy of the map and transfer ownership of that, but then the Offline Map Areas are lost, and the admin is not even able to recreate them for the new owner (though in many cases we wouldn't be able to regardless, since we are unable to see what those map areas even were to begin with).
Allowing admins to transfer web maps with Offline Map Areas would be ideal, but if that is impossible due to technical limitations, please consider allowing admins to at least manage the map areas of web maps they do not own (view/create/delete).
22 Comments
JoeBullard
I see this still exists as a problem, this really needs updating to allow admins to make changes to offline areas. I appreciate there are ways to edit the underlying JSON but this should be an easier option. There are so many instances where this causes trouble, staff members leaving/taking leave etc.
Jg3197
Big upvote for this, it's really problematic, especially given that multiple admins can alter the map itself and the underlying layer schema. Not being able to then recreate offline areas can lead to sync and download errors.
ThomasColson
ESRI? What is the business case of not allowing item transfer if it has an offline map area associated with it?
sredar
@tiztrain This seems to have worked.  BTW, if you change owner without removing the type keyword first, then add it after the map is moved it more or less doesn't work.  That is what I tried first.
tiztrain
@sredar that's a good point. I think in the instructions somewhere you need to remember to click refresh. Next time I do the workflow I will update it with an extra steps that should be included.
Jesse_WI_DNR
Curious if anyone's made a ticket with ESRI about this?  Having just worked through this it feels more like a long-lived bug than an enhancement idea to me.  I was able to move select web map items in bulk to a different owner using the GeoJob Admin tools package, but with that process as well the new owner still cannot modify previously existing offline areas.  For that, the JSON hack workaround was needed (thank you for that BTW @tiztrain !).
It might just be easier to write a python script to do a save as of the web map to a new owner then delete the old one (assuming they are okay with starting from scratch on configuring offline areas...), at least that way the inaccessible data is cleared out.
tiztrain
No worries @Jesse_WI_DNR . I actually got this resolution from an Esri distibuter so I would assume they know.
A script sounds like a great idea, let me know if you end up making one. Would happily use it 🙂
AaronKoelker
We're closing in on nearly six years since I posted this Idea (how time flies!). I see a few comments wondering if this is just a bug but I believe it is expected behavior and have updated the link in my original Idea to go directly to the section saying so. I assumed after all this time that the issue would be a technical one, but given there appears to be JSON workaround... it would be nice to get confirmation from Esri one way or the other.
Elise_Bowne
Please, please make it so we (those with some admin privileges) can move the offline map areas along with the web map to a new owner.  We are losing a lot of people very quickly and need to be able to move these items to new owners.  This is a big problem right now.
svk_jelr
I encounter this problem this week. It would bee nice if the offline areas was moved to the new owner of the map insted of making the cange of ownership imposible without deleting the offline areas.
