Arcade: Decode within GroupBy exression
1363
07-06-2024 04:26 AM
AlexandHall95
Hopefully someone has some advice, I have a a bit of arcade that I can't seem to get to work. The arcade script runs eternally without returning a result:
return GroupBy(
    filteredFs,
    ['lead_contractor_name'],
        {name: 'failed_count', expression: 'Decode(state, "FAILED", 1, 0)', statistic: 'SUM'},
        {name: 'successful_count', expression: 'Decode(state, "SUCCESSFUL", 1, 0)', statistic: 'SUM'}
I have done some debugging and the filteredFs returns as expected, however when attempting to return the GroupBy output, nothing is returned and no errors are flagged.
jcarlson
GroupBy is one of those functions that uses SQL. The value of expression has to be a valid SQL expression, not Arcade. Thankfully, Decode is something we can easily replicate in SQL using a CASE statement.
return GroupBy(
    filteredFs,
        {name: 'failed_count', expression: "CASE WHEN state = 'FAILED' THEN 1 ELSE 0 END", statistic: 'SUM'},
        {name: 'successful_count', expression: "CASE WHEN state = 'SUCCESSFUL' THEN 1 ELSE 0 END", statistic: 'SUM'}
- Josh Carlson
Kendall County GIS
jcarlson
return GroupBy(
    filteredFs,
- Josh Carlson
Kendall County GIS
AlexandHall95
Brilliant, thank you!
