AGOL Edit Widget, how to rename the button Close to Accept
756
05-18-2017 06:07 AM
JoseSanchez
Good morning everyone,
I am using WAB developer edition and customizing the Edit Widget directly on the source code Widget.js
Is there a way to rename the button "Close" to "Accept" or "Save" on the Attribute Inspector  window?
The attribute inspector gets called in the Edit Widget.
RobertScheitlin__GISP
Jose,
   In your apps widgets\Edit\nls\strings.js file change close: "Close", to what ever you want.
JoseSanchez
Hi Robert,
This is what I did in the Widget.js source code. I changed the value for  "label" from this.nls.close to  "Accept"
* Methods for extra works
_addButtonToInspector: function () {
var closeButton = new Button({
//label: this.nls.close,
label: "Accept",
"class": " atiButton closeButton"
}, html.create("div"));
Jose,
   OK that works too.
