How to access feature collection in notebooks
1527
08-17-2021 08:43 AM
Anish_Adhikari
I am a newbie to notebooks and I am trying to write a program which uses aggregation to find out how many points are within a polygon and append that information to a field in the same polygon.  I used the aggregate points function and used it without "output_name" parameter. It ran successfully and returned a feature collection. Now, I have no clue on how to access the feature collection. Screenshot is attached. I would appreciate any help.
xlt208
by Esri Contributor
Hi Anish!
You can add the result to a map widget for visualization–
m = gis.map()
m
m.add_layer(auditcountmru)
You can also convert the output to a Spatially Enabled DataFrame–
import pandas as pd
auditcountmru_sedf = pd.DataFrame.spatial.from_layer(auditcountmru.layers[0])
Here is a sample notebook that might be helpful!
Please let me know if that works for you.
Thanks!
Lingtao
