ArcGIS Notebooks Questions
Other Boards in This Place
Latest Activity
Sort/Filter :
POST
Hi.  My custom web tool/notebook uses an input parameter of datatype = File.  When using the tool to select a file, t...
MaryEllenPerko
by MaryEllenPerko Occasional Contributor
in ArcGIS Notebooks Questions Last Updated 2 weeks ago
0 1
POST
Has anyone encountered issues with auto-complete in notebooks? For example, when I type “arcpy.”, it sometimes change...
ChenChen4
by ChenChen4 Regular Contributor
in ArcGIS Notebooks Questions Last Updated 3 weeks ago
0 5
209
POST
Hello all,I recently came across the workflow of uploading a zipped folder as an item to ArcGIS Online and having the...
AFackler_NAPSG
by AFackler_NAPSG Frequent Contributor
0 3
POST
Good Afternoon,I am currently looking for the a solution that meets the following requirements:KML files can be conve...
dgreenin
by dgreenin Emerging Contributor
in ArcGIS Notebooks Questions Last Updated a month ago
0 0
POST
I used this article to develop a script to backup all my organizations feature layers as zipped FGDBs in AGOL noteboo...
Fynn
by Fynn Emerging Contributor
in ArcGIS Notebooks Questions Last Updated 11-23-2025
0 0
POST
Anybody getting JSONDecodeErrors when using a WHERE date filter?  I am now getting this error after updating my runti...
LakesGISMaps
by LakesGISMaps Occasional Contributor
0 1
POST
All scheduled daily notebooks on AGOL have been failing since 10/29/2025. Even with a newly created notebook that onl...
tssau
by tssau Emerging Contributor
in ArcGIS Notebooks Questions Last Updated 11-04-2025
3 6
862
POST
New! Notebooks as Web Tools in ArcGIS Online (esri.com)I am trying to create a custom print service as depicted in th...
BenjaminJimenez
by BenjaminJimenez Emerging Contributor
in ArcGIS Notebooks Questions Last Updated 10-29-2025
0 0
POST
Scenario: I have a wide variety of PDF and I am using a Notebook script I created in python to extract specific infor...
CristianParra
by CristianParra Emerging Contributor
in ArcGIS Notebooks Questions Last Updated 10-31-2025
0 3
POST
I am able to append the CSV data but it does not pick up the lat/long fields or the spatial field I create with spati...
TL2
by TL2 Frequent Contributor
in ArcGIS Notebooks Questions Last Updated 10-20-2025
0 0
POST
so i'm trying to create an AGOL custom notebook web tool the starting point of the tool is that the user will provide...
StuartMoore
by StuartMoore Frequent Contributor
in ArcGIS Notebooks Questions Last Updated 10-15-2025
0 0
POST
Support for TensorFlow will be removed in the following releases. ArcGIS API for Python 2.4.2 (October 2025)ArcGIS Pr...
NicholasGiner1
by NicholasGiner1 Esri Contributor Esri Contributor
in ArcGIS Notebooks Questions Last Updated 10-13-2025
0 0
POST
I noticed that in the release notes for 11.5 there is now the ability to set up a webhook receiver.  The documentatio...
Justin_Greco
by Justin_Greco Frequent Contributor
in ArcGIS Notebooks Questions Last Updated 09-29-2025
0 1
POST
I'm trying to push updates between layers existing in my 10.9.1 Portal and my 11.5 Portal, hopefully using my 10.9.1 ...
CBarrett
by CBarrett Occasional Contributor
in ArcGIS Notebooks Questions Last Updated 09-23-2025
0 0
POST
I’m exploring ways to customize the runtime for ArcGIS Notebooks. I know ArcGIS Online only provides the standard and...
VenkataKondepati
by VenkataKondepati Regular Contributor
in ArcGIS Notebooks Questions Last Updated 09-17-2025
0 1
133 Subscribers
