call/run another notebook
4511
8
09-09-2021 12:46 AM
StuartMoore
i'm very new to notebooks but i have two questions that i couldn't find an answer for in the community
is it possible to call/run a notebook from a webhook, ie survey completed in Survey123 initiates the notebook?
and my second question is it possible to call/run another Notebook at the end of Notebook (ie running Notebook A but run Notebook B to create some data etc)
thanks
Stu
StuartMoore
thanks for the reply i'll have a play
shikhar_deep
Hi @StuartMoore,
Thank you for your interest in ArcGIS Notebooks. The current released version of ArcGIS Enterprise (10.9) do not support executing a notebook from webhooks. We are actively actively working on adding support for this in near future.
Although, you can call a notebook from another notebook using execute_notebook operation available in ArcGIS API for Python:
https://developers.arcgis.com/python/api-reference/arcgis.gis.nb.html?highlight=execute_notebook#arc...).
Also, please ensure the version of ArcGIS API for Python used in notebook has support for this operation.
Thanks & Regards
Shikhar Deep
StuartMoore
thanks @shikhar_deep i've had a play but can't seem to get it to work, it wont even find the notebookmanager maybe its not implimented in Notebooks in ArcGIS Online
shikhar_deep
Hi @StuartMoore  if you may try the following.
Thanks
Shikhar Deep
DougZietz1
Shikhar,
From the documentation, this looks like this is an Enterprise only method because one needs to get access to the notebook server. Am I interpreting that correctly?
If not, how could I run a notebook from a notebook on AGOL?
Thank you
DISIG
Hello everybody,
working in Agol and trying to execute a notebook
is it the correct syntax?
i have an error message but the myItem var is a arcgis.gis.ItemDISIG_1-1670314672035.png
usdajoy
@DISIC Did you every figure this out? I am stuck at the exact same spot with the same error.
GLCAdmin
I think you just need gis.content.get rather than gis.content.search
from arcgis.gis import GIS
gis = GIS("home")
nb_server = gis.notebook_server[0]
notebook_item = gis.content.get('your notebook item ID')
nb_mgr = nb_server.notebooksmanager
nb_mgr.execute_notebook(notebook_item)
