Problem with Setting Network Dataset
1366
11-22-2023 07:29 AM
UlfahRahmah
I can't set up my network data set through the properties, because there is no option or button "ok" in the window.
Is there anyone who know what should I do?
MelindaMorang
The button appears to be below the edge of the screen.  Unfortunately, this dialog can't be resized.  Can you adjust your Windows screen resolution or scaling?
JaySandhu
You can try using the keyboard shortcut keys. Try Alt and O for the Ok button.
So press both keys together, Alt O
Jay Sandhu
UlfahRahmah
Thanks a lot for your help, it works.
