Network Analyst - ArcGis Pro - Location-Allocation inside Service Area
1102
04-15-2022 01:18 AM
AnneMarieIndrelid
Hi!
We have made an Service Area with Network Analyst.  Is it possible to use Location-Allocation inside this Service Area?  We are trying to find the optimal place inside the Service Area to send goods to customers. We have tried to use Point Barriers as the facility, and demand points as our customers.  The analyst is failing because of the facility.
JaySandhu
You can use the service area to select the demand location and candidate facility locations that fall inside it and then load only those into the Location-Allocation and solve. Is that what you need to achieve? Or do you have some other constraint?
Jay Sandhu
