NA Route Rest services gives error
7421
10
03-14-2012 09:43 PM
MuhammadWaqar_ul_islam
I have create Na Routing  sample to test
on arcgis info its works fine create route on the data
but when i create Network Analysis services through Arcgis server and  using rest services in silverlight sample
http://help.arcgis.com/en/webapi/silverlight/3.0/samples/start.htm#Routing
its gives error
Black"Routing error: Unable to complete operation unable to find atribute invalid Context" my rest services
i Have discuss this topic on arcgis silverlight forum one of esri person forward me to this forum
My services is
http://10.1.18.191/ArcGISSERVER/rest/services/network_Test/NAServer/Route
services properties
Network Layer: Route
Layer Type: esriNAServerRouteLayer
Impedance: Meters
Restrictions: Oneway, RestrictedTurn
Accumulate Attribute Names:
Attribute Parameter Values:
Use Hierarchy: false
Hierarchy Attribute Name:
Hierarchy Level Count: 0
Hierarchy Max Values:
Hierarchy Num Transitions:
Snap Tolerance: 0
Max Snap Tolerance: 5000
Snap Tolerance Units: esriMeters
Ignore Invalid Locations: true
Restrict U-Turns: esriNFSBAllowBacktrack
Output Spatial Reference: 32642
Find Best Sequence: false
Use Start Time: false
Start Time: Sat, 30 Dec 1899 08:00:00 GMT
Use Time Windows: false
Preserve First Stop: true
Preserve Last Stop: true
Output Line Type: esriNAOutputLineTrueShape
Directions Language: en-US
Direction Style Names: NA Desktop, NA Navigation
Directions Length Units: esriNAUMiles
Directions Time Attribute:
Network Analysis Classes:
Class Name: Stops
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Address, Label, Location, Stop, WayPoint, Description, Title, DepotName
Field Name: RouteName
Default Value:
Candidate Fields: RouteName, Route, RouteID
Field Name: Sequence
Default Value: 1
Candidate Fields:
Field Name: TimeWindowStart
Default Value:
Candidate Fields: TimeWindowStart1, TWStart1, FromTime1, FromTimeWindow1, FromTW1, From1, TimeWindowStart, TWStart, FromTime, FromTimeWindow, FromTW, From
Field Name: TimeWindowEnd
Default Value:
Candidate Fields: TimeWindowEnd1, TWEnd1, ToTime1, ToTimeWindow1, ToTW1, To1, TimeWindowEnd, TWEnd, ToTime, ToTimeWindow, ToTW, To
Field Name: SourceID
Default Value: -1
Candidate Fields: SourceID, SID, Source
Field Name: SourceOID
Default Value: -1
Candidate Fields: SourceOID, SOID
Field Name: PosAlong
Default Value: 0
Candidate Fields: PosAlong, PA, Pos
Field Name: SideOfEdge
Default Value: 2
Candidate Fields: SideOfEdge, SOE
Field Name: CurbApproach
Default Value: 0
Candidate Fields: CurbApproach, SideOfStreet, SideApproach, CurbSide, Curb
Field Name: Status
Default Value: 0
Candidate Fields:
Field Name: Attr_Meters
Default Value: 0
Candidate Fields: Attr_Meters, Meters
Class Name: Barriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Address, Label, Location, Barrier, Description, Title
Default Value: -1
Default Value: -1
Default Value: 0
Default Value: 2
Default Value: 0
Field Name: Status
Default Value: 0
Candidate Fields:
Field Name: FullEdge
Default Value: 0
Candidate Fields: FullEdge, IsFullEdge, BlockEntire
Field Name: BarrierType
Default Value: 0
Candidate Fields: BarrierType, BarType, BarrierTyp
Default Value: 0
Class Name: PolylineBarriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Label, Locations, Barrier, Description, Title
Field Name: Locations
Default Value:
Candidate Fields: Locations, LocRanges
Default Value: 0
Default Value: 1
Class Name: PolygonBarriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Default Value:
Default Value: 0
Default Value: 1
Network Dataset: RoadNetWork_ND
Network Attributes:
Meters
Usage Type: esriNAUTCost
Units: esriNAUMeters
Data Type: esriNADTDouble
Parameter Names:
Oneway
Usage Type: esriNAUTRestriction
Units: esriNAUUnknown
Data Type: esriNADTBoolean
Parameter Names:
RoadClass
Usage Type: esriNAUTDescriptor
Data Type: esriNADTInteger
Parameter Names:
RestrictedTurn
Parameter Names:
Network Sources:
Street
Element Type: esriNETEdge
Source Type:esriNSTEdgeFeature
RoadNetWork_ND_Junctions
Element Type: esriNETJunction
Source Type:esriNSTSystemJunction
RestrictedTurns
Element Type: esriNETTurn
Source Type:esriNSTTurnFeature
Supported Operations: Solve Route
i have attached gdb in Northkarachi.gdb.rar
for u testing
help me out what i m doing wrong
DmitryKudinov
Hi Muhammad,
Please try building a route on your network dataset using ArcMap first - will it work?
If it works, then download Fiddler http debugger tool (http://www.fiddler2.com/fiddler2/version.asp) and have it running while sending requests from your Silverlight application.
Check with Fiddler that all the attributes which are sent by the application present in your network dataset.
if there are some invalid attributes in requests whereas you do not specify them in your Silverlight code, try overriding these values explicitly.
Let us know if it doesn't help.
Dmitry
I have tired to used fiddler utilities
unable to understand fiddler result
what i get from fiddler i m paste
GET /ArcGISSERVER/rest/services/network_Test/NAServer/Route/solve?stops=%7b%22features%22%3a%5b%7b%22geometry%22%3a%7b%22x%22%3a303831.809058898%2c%22y%22%3a2763214.26130914%2c%22spatialReference%22%3a%7b%22wkid%22%3a32642%7d%7d%7d%2c%7b%22geometry%22%3a%7b%22x%22%3a304055.883835564%2c%22y%22%3a2763292.20034173%2c%22spatialReference%22%3a%7b%22wkid%22%3a32642%7d%7d%7d%5d%7d&returnDirections=false&returnRoutes=true&returnStops=false&returnBarriers=false&returnPolylineBarriers=false&returnPolygonBarriers=false&outSR=32642&ignoreInvalidLocations=true&preserveFirstStop=true&preserveLastStop=true&useHierarchy=true&outputGeometryPrecision=0&outputGeometryPrecisionUnits=esriUnknownUnits&f=json& HTTP/1.1
GET /ArcGISSERVER/rest/services/network_Test/NAServer/Route/solve?stops={"features":[{"geometry":{"x":303831.809058898,"y":2763214.26130914,"spatialReference":{"wkid":32642}}},{"geometry":{"x":304055.883835564,"y":2763292.20034173,"spatialReference":{"wkid":32642}}}]}&returnDirections=false&returnRoutes=true&returnStops=false&returnBarriers=false&returnPolylineBarriers=false&returnPolygonBarriers=false&outSR=32642&ignoreInvalidLocations=true&preserveFirstStop=true&preserveLastStop=true&useHierarchy=true&outputGeometryPrecision=0&outputGeometryPrecisionUnits=esriUnknownUnits&f=json& HTTP/1.1
{"error":{"code":400,"message":"Unable to complete  operation.","details":["Unable to find attribute .  Invalid context.  NALayer saved on server with token ec21144d19a2405db79d867307031d55_1325852015."]}}
what next to solved this issue
DmitryKudinov
Hi Muhammad,
Looking at the error message, it might be the case that the network dataset on your Server is different from the one you used in ArcMap during service authoring (when you were creating the MXD which was later published).
So, please first verify that the network dataset on server is the same.
If network dataset is exactly the same on both Desktop and Server and service still fails, rerun the same request again and note the error message, particularly the part about "NALayer saved on server with token ...". The token value will tell you the name of LYR file in ArcGIS Server output directory (_ags<token>.lyr) - find this file, open it in ArcMap, and try solving it. Most probably the solve will fail in ArcMap as well and this will give you much better clue on what is going wrong.
Dmitry
i have open the _ags token  layer ( from output directory of arcgisserver)  in arcmap
and solved the solution in arcmap
its works fine
no error occurs
i have created new NA ROUTE SERVICES
using fiddler it gives this error
GET /ArcGISSERVER/rest/services/Network_ANAlysis/NAServer/Route/solve?stops=%7b%22features%22%3a%5b%7b%22geometry%22%3a%7b%22x%22%3a303867.994872106%2c%22y%22%3a2763839.39565207%2c%22spatialReference%22%3a%7b%22wkid%22%3a32642%7d%7d%7d%2c%7b%22geometry%22%3a%7b%22x%22%3a303975.44353541%2c%22y%22%3a2762960.26995024%2c%22spatialReference%22%3a%7b%22wkid%22%3a32642%7d%7d%7d%5d%7d&returnDirections=false&returnRoutes=true&returnStops=false&returnBarriers=false&returnPolylineBarriers=false&returnPolygonBarriers=false&outSR=32642&ignoreInvalidLocations=true&preserveFirstStop=true&preserveLastStop=true&useHierarchy=true&outputGeometryPrecision=0&outputGeometryPrecisionUnits=esriUnknownUnits&f=json& HTTP/1.1
when i open this ags_file in arcmap its work fine
help me out please
DmitryKudinov
Hi Muhammad,
Please open the Route description page (http://<server>/ArcGISSERVER/rest/services/Network_ANAlysis/NAServer/Route) in a browser and look for all the attributes of the esriNAUTCost usage type; write down the name of the attribute you are interested to solve on.
Next, in your HTTP request, specify the impedanceAttributeName parameter with the value set to attribute name you noted at the previous step.
Please let us know what will be the result.
Dmitry
Hi Muhammad,
Dmitry
Network Attributes:
Meters
Parameter Names:
Oneway
Parameter Names:
RoadClass
Parameter Names:
RestrictedTurn
Parameter Names:
Network Sources:
Street
RestrictedTurns
i have also solved  the route on  http://<server>/ArcGISSERVER/rest/services/Network_ANAlysis/NAServer/Route/Solve
Result i get
Directions:
Route: 1.Location 1 - Location 2
Summary:
    Total Length: 290.725276854782 Total time: 0 Total Drive Time: 0
    Envelope:
        Envelope:
        XMin: 303831.274002066
        YMin: 2763214.2613
        XMax: 304055.8838
        YMax: 2763300.41672698
Directions:
    Text: Start at Location 1 Length: 0 Time: 0 ETA: 12/30/1899 12:00:00 AM Maneuver: esriDMTDepart
    Compressed Geometry: +1+98mn+2kaes+0+0
    Text: Go east Length: 176.920221727059 Time: 0 ETA: 12/30/1899 12:00:00 AM Maneuver: esriDMTStraight
    Compressed Geometry: +1+98mn+2kaes+5h+7
    Text: Turn left Length: 63.667495198 Time: 0 ETA: 12/30/1899 12:00:00 AM Maneuver: esriDMTTurnLeft
    Compressed Geometry: +1+98s8+2kaf3-3+20
    Text: Turn right Length: 50.1375599297227 Time: 0 ETA: 12/30/1899 12:00:00 AM Maneuver: esriDMTTurnRight
    Compressed Geometry: +1+98s5+2kah3+1j+1
    Text: Finish at Location 2, on the right Length: 0 Time: 0 ETA: 12/30/1899 12:00:00 AM Maneuver: esriDMTStop
    Compressed Geometry: +1+98to+2kah4+0+0
Routes
#records: 1
    ObjectID: 1
    Name: Location 1 - Location 2
    FirstStopID: 1
    LastStopID: 2
    StopCount: 2
    Total_Meters: 290.725276854782
    Shape_Length: 290.725186211174
    Polyline:
    Path0:[303831.274,2763228.1893],[303885.5364,2763230.274],[303895.8829,2763230.6672]...5 more...
i do not understand what ur asking in above line  but what i understand is impedanceAttributeName is
Impedance Attribute Name: METER
{  RESULT IN JSON
  "directions" : [
      "routeId" : 1,
      "routeName" : "Location 1 - Location 2",
      "summary" : {
        "totalLength" : 290.725276854782,
        "totalTime" : 0,
        "totalDriveTime" : 0,
        "envelope" : {
          "xmin" : 303831.274002066,
          "ymin" : 2763214.2613,
          "xmax" : 304055.8838,
          "ymax" : 2763300.41672698,
          "spatialReference" : {
            "wkid" : 32642
      "features" : [
          "attributes" : {
            "length" : 0,
            "time" : 0,
            "text" : "Start at Location 1",
            "ETA" : -2209161600000,
            "maneuverType" : "esriDMTDepart"
          "compressedGeometry" : "+1+98mn+2kaes+0+0"
          "attributes" : {
            "length" : 176.920221727059,
            "time" : 0,
            "text" : "Go east",
            "maneuverType" : "esriDMTStraight"
          "compressedGeometry" : "+1+98mn+2kaes+5h+7"
          "attributes" : {
            "length" : 63.667495198,
            "time" : 0,
            "text" : "Turn left",
            "maneuverType" : "esriDMTTurnLeft"
          "compressedGeometry" : "+1+98s8+2kaf3-3+20"
          "attributes" : {
            "length" : 50.1375599297227,
            "time" : 0,
            "text" : "Turn right",
            "maneuverType" : "esriDMTTurnRight"
          "compressedGeometry" : "+1+98s5+2kah3+1j+1"
          "attributes" : {
            "length" : 0,
            "time" : 0,
            "text" : "Finish at Location 2, on the right",
            "maneuverType" : "esriDMTStop"
          "compressedGeometry" : "+1+98to+2kah4+0+0"
  "routes" : {"spatialReference" : {
      "wkid" : 32642
    "features" : [
        "attributes" : {
          "ObjectID" : 1,
          "Name" : "Location 1 - Location 2",
          "FirstStopID" : 1,
          "LastStopID" : 2,
          "StopCount" : 2,
          "Total_Meters" : 290.725276854782,
          "Shape_Length" : 290.725186211174
        "geometry" :
          "paths" :
              [303831.274, 2763228.1893],
              [303885.5364, 2763230.274],
              [303895.8829, 2763230.6672],
              [303964.0281, 2763233.2845],
              [304008.0642, 2763234.9721],
              [304008.0642, 2763235.0171],
              [304005.4796, 2763298.587],
              [304055.5837, 2763300.4167]
  "messages" : [
What next to solved this
and Many thanks for providing help
please reply to this thread
awaiting for your reply
