Issues with call Arcpy script in C#
839
05-04-2018 02:17 AM
Yang
Hey All,
I have a python script that I would like to call from form events in WPF project. The C# code snippet to call Arcpy script like below.
var startInfo = new ProcessStartInfo() {
     CreateNoWindow = false,
     UseShellExecute = false,
     FileName = pathToArcGISPythonRuntime,
     WindowStyle = ProcessWindowStyle.Hidden,
     Arguments = pathToMyArcpyScript+""+allTheParams
var exeProcess= Process.Start(startInfo);
exeProcess.WaitForExit();‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The script is used for create a Network Dataset and publish it as a NAService.The script runs well in ArcGIS Desktop and in Cmd console every time.But I'm facing two issues when call it in C# like the method above.
1.The Arcpy script will failed at import arcpy in some computers when runing the WPF project while other computers work well . All the Computers installed  the same ArcGIS Desktop 10.6 and ArcGIS Server10.6 with the right licence.
2.In some computers when the Arcpy script call the arcpy.CreateNetworkDatasetFromTemplate_na() method, there will be a python.exe has stopped working error popup like the picture below.If i run the Arcpy script in Cmd console in those computers there is no error.
The full python script is attached,Any suggestions or ideas about issues would be very appreciated!
Thanks!
Yang
