No data available after update to 2023.3
1066
5
01-10-2024 10:16 AM
LouEarly
After upgrading to 2023.3 we are showing "No Data Available".   It was working briefly after the upgrade then this occurred.  Restarted services with no change.
GeoJosh
Hi @LouEarly,
Is this issue present on all components or just the component that you have pictured? If the former, please log into ArcGIS Monitor as an administrator and click Administration > Database and click "Run now" under "Data Retention Policy". Then, run one of your component's observers again and see if the chart is populated.
Josh
WhitneyLoy
I am also experiencing the same issue with my deployment.
LouEarly
According to ESRI support this is a known bug and will be resolved with a patch to be released by the end of january 2024
Laura
by MVP Regular Contributor
I am also receiving these errors a few days post deployment.
WhitneyLoy
Any update on this? Error is rendering Monitor useless at this point.
