Monitor Gallery
1289
04-03-2023 12:18 PM
by Anonymous User
Not applicable
is this link below that goes to the ArcGIS Monitor Gallery outdated?  This looks like things that worked with prior releases and not 2023 version. Is there a new gallery that works only with 2023?
@DerekLaw
ReeseFacendini
Esri Alum
Here is the link to the ArcGIS Monitor 2023 gallery, but ArcGIS Monitor 2023 doesn't support extensions like the 10.8.1 version did. If there is functionality that you'd like to see added to the new generation, please use this Ideas page https://community.esri.com/t5/arcgis-monitor-ideas/idb-p/arcgis-monitor-ideas
ReeseFacendini
Esri Alum
DerekLaw
Esri Esteemed Contributor
Hi @Anonymous User,
@ReeseFacendini's post is correct. The add-ins found in the old ArcGIS Monitor gallery do not work with ArcGIS Monitor 2023. He shared a link to a couple of unsupported dev samples available in the ArcGIS Monitor 2023 gallery.
Hope this helps,
TarigAhmedmemphistngovAhmed
Hello Y'all ,
I know MissionCriticalAnalysis is not supported. But I would love to get help on it.
I'm getting this error:
C:\ArcGISMonitorExamplesExtras_Tarig\arcgis-monitor-admin-utility\dist>AdminUtility -f SampleConfig.json -o analysis
Invalid \escape: line 9 column 20 (char 178)
File "AdminUtility.py", line 8, in main
File "Modules\Builder\builder.py", line 18, in __init__
File "Modules\Builder\builder.py", line 75, in _get_config
File "Modules\Inputs\init_config.py", line 6, in __init__
File "Modules\Inputs\init_config.py", line 10, in _read_config_file
File "Modules\Helper\helper.py", line 37, in read_config_file
File "json\__init__.py", line 293, in load
File "json\__init__.py", line 346, in loads
File "json\decoder.py", line 337, in decode
File "json\decoder.py", line 353, in raw_decode
json.decoder.JSONDecodeError: Invalid \escape: line 9 column 20 (char 178)
None
Here's my sampleConfig.json:
"server":{
"url":"http://memgisazmonitor:30080",
"username": "gismonitor",
"password": "#gismonitor123!"
"analysis":[
{"file":"C:\ArcGISMonitorExamplesExtras_Tarig\arcgis-monitor-admin-utility\dist\MissionCriticalServices.json"}
Kind regards,
Tarig Ahmed, GISP
GIS Administrator
Information Technology Division
150 Peabody Place, 1st Floor
Memphis, TN 38103
(C) (469) 261.0849
Tarig.Ahmed@memphistn.gov
