Monitor 2023.3 database connection
3233
13
12-15-2023 01:58 PM
Pat_Gallagher
I upgraded our ArcGIS Monitor to 2023.3 and now the database data is not showing correctly. There is a new Alerts section in the database and that seems to be breaking the database links to Monitor.
ArcGIS Monitor 2023.2
ArcGIS Monitor 2023.3
After the upgrade I am not getting any metric data showing in any serial chart. It looks like the database is not accepting any new information.
AYUSHYADAV
Hi @DerekLaw ,
I can see from the ArcGIS Monitor documentation that version 2023.3.1 has been released.
But I can't find the setup for the same from my Esri. Below is the screenshot attached for the same
Can you tell me when we can expect to get it available on my Esri?
Thanks
Ayush
DerekLaw
Esri Esteemed Contributor
Hi @AYUSHYADAV,
ArcGIS Monitor 2023.3.1 is scheduled to be released today. I will post an update when it's available on MyEsri. Thanks for your patience.
UPDATE: The release is now available
Hope this helps,
AYUSHYADAV
Thanks for the update! @DerekLaw .
TimLehn
I just upgraded to this version and had same issue.  In trying to resolve it I somehow lost connectivity to my database and it now would like me to register a database but when i try there are lots of errors with GUI.
error: insert into "strategies_registry" ("description", "name", "r_id", "subtype", "type") values ($1, $2, $3, $4, $5), ($6, $7, $8, $9, $10), ($11, $12, $13, $14, $15), ($16, $17, $18, $19, $20), ($21, $22, $23, $24, $25), ($26, $27, $28, $29, $30), ($31, $32, $33, $34, $35), ($36, $37, $38, $39, $40), ($41, $42, $43, $44, $45) on conflict ("r_id") do update set "name" = excluded."name", "description" = excluded."description", "type" = excluded."type", "subtype" = excluded."subtype" - there is no unique or exclusion constraint matching the ON CONFLICT specification
