Monitor 2023.3.1: Unable to register a component: SQL Server
830
10-03-2024 12:25 PM
RickChu
Hello,
We have recently setup ArcGIS Monitor 2023.3.1. I have registered several components but I'm having trouble registering a SQL Server component..
On the screen where you configure the Address, Database, username and password, I filled in the fields and clicked "Register Component". After a few seconds I get this message:
An error occurred running the observer
Knex: Timeout acquiring a connection. The pool is probably full. Are you missing a .transacting(trx) call?
I have verified that the userid and password are correct and that no firewalls are blocking access to SQL Server.
I had no trouble adding a Postgresql server
Any thoughts on what may cause this error?
RickChu
There is another post for the same error but a different ESRI product. They recommended restarting the service. I restarted ArcGIS Monitor Service and Postgresql. After the restart, I was able to register SQL Server.
I don't know the root cause, but it appears that my problem is resolved.
RickChu
StevenBeothy
I had a client who had this same error and their issue was resolved by them updating their NSG in Azure to allow the ArcGIS Monitor server. Check to see if you have a firewall rule blocking the ArcGIS Monitor Server or Agent.
Shawn_NG
@RickChu Since your are registering SQL Server database, did you follow the pre-requisite steps mentioned in document https://doc.arcgis.com/en/monitor/2023.3/get-started/windows/register-sql-server-databases.htm#ESRI_...
