Invalid Authentication on First Token Request
621
10-14-2025 08:17 AM
DavidWittmann
Spoiler
Exact same command (parameters, username, and password) fails 1st time & succeeds 2nd timeExact same command (parameters, username, and password) fails 1st time & succeeds 2nd time
I've noticed an issue with authentication in ArcGIS Monitor 2025.0.1 where the first attempt with valid credentials fails but the second attempt with the same credentials successfully authenticates.
I've seen it consistently both with re-registering Agents like in the screenshot above and in the Monitor Server login like in the screenshot below.
Inspecting the Network traffic, the token request (Request URL: https://agmserver:port/arcgis/auth/token) has the same payload for both the failed and successful request.
Is there a known issue that causes token requests to fail on first attempt?
MarlonAmaya
Hi @DavidWittmann ,
Do your passwords have special characters? If you are able to consistently reproduce, I recommend you create a support ticket so we can confirm behavior and log a defect.  Thank you
Timothy
Hi Marlon, I'm experiencing the same issue, whilst registering the agent and when logging in as a user through the website using DNS and FQDN:30443.
I have a special character in my primary server account and have changed in the ArcGIS Monitor Server GUI but still had no success.
