Inaccurate duration of Portal alerts
852
07-25-2023 07:58 PM
EricAnderson_DHS
We have a Portal component set up to alert when the Federation Validation does not succeed. We are exporting this to a feature service, and if you look at the Created and Resolved timestamps, these only add up to about 7 minutes. However, the Duration field says 13 minutes. Why such a large discrepancy?
GeoJosh
Hi Eric, the "Created At" field tracks when the alert record is inserted into ArcGIS Monitor's data repository, not when the alert is actually opened. If you check the difference between the "Opened At" and "Closed At" fields, you should find that the duration is accurate.
Josh
GeoJosh
Josh
