Finding a Component Id in Monitor 2023.2.0
729
6
04-17-2025 12:04 PM
GrantSmith122
Hello, I am having some trouble setting up Notifications in Monitor 2023.2.0. I have a component (service) that is extremely critical to a high-stakes application we are rolling out. I would like to get a notification if that service fails to respond to a critical number of requests. I have the proper Alert set up and the threshold values defined, but when I go to create a Notification so I could get an email if the Alert is triggered, I have no idea what I am doing.
For the notification, I have it set to notify when Alerts = Updated And Component ID = ????. How do I find a given component's ID? I can't seem to find anything in the component's setting page, so I'm unsure how I would get this info. If anyone has ideas, please let me know.
GrantSmith122
Okay so in the URL for a component I can find somenumbers: /arcgis/monitor/monitoring/components/7465058/metrics/438238. The 74 number is the component ID (I think), and the 43 number is the metric ID (I think). The issue I'm running into now is that when I attempt to input a Service's Component ID / Metric ID to the notification, the numbers aren't available. I must be missing something
DerekLaw
Esri Esteemed Contributor
Hi @GrantSmith122
I haven't run ArcGIS Monitor 2023.2.0 in a long time, so I don't recall the UI/UX.
Can you upgrade your ArcGIS Monitor instance to v. 2024.1.1 - the latest release? Not only does it contain many new feature enhancements and bug fixes, it also displays the component ID for components on their overview tab, like this:
> ... but when I go to create a Notification so I could get an email if the Alert is triggered, I have no idea what I am doing.
In Monitor 2024.1.1, you can create the notification this way,
  • Navigate to Administration > Notifications > Create Notification > type is Custom Notification
  • Provide a name and description
  • For Subscribe to Events,
    • Add Event
    • Alerts - Added
  • For Condition
    • Component ID is [component ID of your service]
    • Status is Critical
Then you can input the email address and optionally enable a webhook.
Conceptually, you have enabled a notification to be created, whenever a new Alert with status critical is created for the service (based on the component ID).
I am not 100% sure, but I believe the notification configuration experience in Monitor 2023.2.0 is similar. But as I said, it's been awhile.
Hope this helps,
GrantSmith122
Hi Derek,
Thanks for the reply. I haven't considered upgrading but should maybe look into that. To confirm I cannot see something's ID in 2023.2 on the Overview tab.
What is strange to me is that I can (possibly) see the component ID for a given item in the URL, but those ID values then don't appear in the notification setup. That is what is tripping me up the most, and seems like unexpected behavior
DerekLaw
Hi @GrantSmith122,
FYI, ArcGIS Monitor 2023.2 was retired in Dec 2024. Please see the ArcGIS Monitor product life cycle document. I recommend you upgrade Monitor.
Correct. We added this functionality in Monitor 2023.3, see the release blog (side note).
Perhaps when we enabled displaying the component ID on component overview pages in Monitor 2023.3, we also made it a queryable attribute field for configuring notifications? It's been over a year so I cannot recall exactly.
Can you at least upgrade to the Monitor 2023.3.1 release? I know moving to Monitor 2024.x is a bigger lift because of the requirement to install AM Agents on host machines.
Hope this helps,
GrantSmith122
Hey Derek,
I upgraded to 2023.3.1, I can now more clearly see the component and metric ID values, but I am growing increasingly frustrated with how the IDs act. I've attached 2 screenshots of one of my components (map server on a standalone ArcGIS Server). Yesterday at 2:30 pm, the component ID was 11050569; this morning at 8:45 am the component ID has now changed to 11716560. How could this possibly be?
This is very frustrating since I spent a bunch of time yesterday setting up notifications for specific components and metrics, but now everything is broken because all the ID values change. I did not mess with any component registrations in ArcGIS Monitor and nothing was done to the ArcGIS Server overnight to cause any disruptions.
DerekLaw
Hi @GrantSmith122,
Apologies for the late reply. I was working at the ERGIS 2025 conference last week in Houston, TX.
I have not seen this behavior in ArcGIS Monitor before. Once a component is "registered" with Monitor, it is assigned a unique ID and this value does not change.
The only think I can think of, in the time period from 2:30 pm to the next day at 8:45 am - was the service republished? Perhaps someone re-published the service with some data updates? I think this might change the component ID. I'm sorry that it messed up your configured notifications.
Since last Wed, have you noticed the component ID changing again? or has it remained the same value of 11716560?
