Error when testing System Log Parser for ArcGIS Task Add-on
1720
04-17-2019 03:06 PM
MikeSchonlau
I'm trying to add the System Log Parser for ArcGIS Task Add-on to Monitor 10.7. I'm getting the error below:
I've followed the pdf instructions exactly. Any thoughts on what I'm doing wrong here? Thanks
Tags (1)
JohnGraham2
Hi Michael,
The Program field needs the path to the slp.exe. Click the button on the right side to browse to the slp.exe. Then Test again.
Best Regards,
John
JohnGraham2
Hi Michael,
Best Regards,
John
MikeSchonlau
Got that full path added. Now I'm getting this error: System.Exception: An error occurred during log collection: ArcGIS Log Query Error: Invalid token, ClientID does not match. StatusCode: 498 at ESRI.PS.EIST.SystemLogParser_Plus.CLI.StartHere.Main(String[] args)
Instead of using my server domain name, I tried using my server's elastic ip address and that worked!! Thanks for your help.
