ArcGIS Monitor 2025 - does it report mapservice crashing
238
08-27-2025 06:11 AM
AntheaTung
Wondering does ArcGIS Monitor 2025.1 have ability to monitor and report when a mapservice crashed or is not responding?
Thank you.
Anthea
CodyPatterson
MVP Regular Contributor
Hey @AntheaTung
There is a Metric on the mapservices called Requests Timed Out (req) which would be able to show you when a request is timing out, along with a Requests Failed (req), you could set up an alert with these to check if they pass a certain threshold to inform you.
Cody
DerekLaw
Esri Esteemed Contributor
Hi @AntheaTung,
Another metric to consider is the Requests Failed - which shows the total number of failed service requests on a service component. This is anther indicator that something might not be working correctly with the service.
Hope this helps,
AntheaTung
Thank you 🙂
