ArcGIS Monitor 2025.0 Oracle Database Observer Fails
271
07-24-2025 07:24 PM
Justin_Greco
We have been monitoring our Oracle databases using Monitor, but after the upgrade to 2025.0, we are not getting any metric data.  I verified that our DB is above 19.3.  Checking the logs and I get the following error for the SQL that gets geodatabase datasets:
NJS-100: national character set id 871 is not supported by node-oracledb in Thin mode
MarlonAmaya
@Justin_Greco ,
The error you are referencing was submitted as a defect.
https://support.esri.com/en-us/bug/oracle-database-does-not-monitor-metrics-in-arcgis-moni-bug-00017...
However, after further investigation, there is going to be an additional requirement at 2025 to gather metrics for Oracle. This is the requirement to configure extproc on the database.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/configure-oracle-extpr...
This is due to the new functionality at 2025 of gathering inventory on datasets inside the geodatabase. Our documentation will be update.
MarlonAmaya
Hi @Justin_Greco ,
Are you seeing the following error in your inventory observer:
WITH UNFILTERED_TABLES AS ( SELECT GI.PHYSICALNAME AS "table_name", CASE WHEN GI.DEFINITION IS NULL THEN 'other' WHEN XMLQUERY('/*/ShapeType' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT) IS NULL THEN NULL WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'point') > 0 THEN 'point' WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'line') > 0 THEN 'line' WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'polygon') > 0 THEN 'polygon' ELSE 'other' END AS "geometry_type", CASE WHEN BITAND(TR.OBJECT_FLAGS, POWER(2, 3)) <> 0 THEN 'traditional' WHEN BITAND(TR.OBJECT_FLAGS, POWER(2, 25)) <> 0 THEN 'branched' ELSE NULL END AS "versioned_type", CASE WHEN BITAND(TR.OBJECT_FLAGS, POWER(2, 3)) = 0 AND BITAND(TR.OBJECT_FLAGS, POWER(2, 18)) <> 0 THEN 1 ELSE 0 END AS "is_archived" FROM TABLE_REGISTRY TR LEFT JOIN GDB_ITEMS_VW GI ON TR.OWNER || '.' || TR.TABLE_NAME = GI.PHYSICALNAME ) SELECT * FROM UNFILTERED_TABLES WHERE "geometry_type" IS NULL OR "geometry_type" <> 'other' ORDER BY "table_name" ASC - ORA-31011: XML parsing failed ORA-19213: error occurred in XML processing at lines 1 LPX-00245: extra data after end of document ORA-06512: at "SYS.XMLTYPE", line 272 ORA-06512: at line 1
MarlonAmaya
@Justin_Greco ,
MartinKrál
Hello
In our customer's environement same SQL ended with ORA-00942 table or view does not exists (not with ORA-31011). Problem in our case was not st_shapelib configuration,  but it was  that above mentioned SQL references GDB_ITEMS_VW and not SDE.GDB_ITEMS_VW. We created synonym for that view and then it started to work.
