ArcGIS Monitor 2023 using AWS managed services
1878
04-13-2023 10:59 PM
AnthonyRyanEQL
Hi there,
I have 2 questions
  1. As the application now supports PostgreSQL database, could AWS Aurora PostgreSQL RDS be used instead?
  2. Having ArcGIS Enterprise in AWS with HA requirements, how would you implement ArcGIS Monitor in HA? This leads on from my first question about using a managed database.
Thanks
Tags (4)
AndrewSakowicz
We verified: AWS Aurora PostgreSQL RDS works.
As far as Active/Passive,  the main challenge I see is that server and agents config files would have to be synchronized between Active and Passive nodes, see above back up help url.
AndrewSakowicz
1. We are running validation tests and will update our documentation shortly. 2.  ArcGIS Monitor server or agent don't have HA capabilities.  however, if the PG repository is in HA, restoring ArcGIS Monitor instance might be fairly quick.  If this is not possible, users can back on and restore to new instance,  see https://doc.arcgis.com/en/monitor/latest/administration/windows/back-up-and-restore-your-deployment....
AnthonyRyanEQL
Thanks for this. As this will be all sitting in AWS, if I have Monitor sitting in an active/passive type of arrangement behind a load balancer, Would something like that work after your tests have confirmed AWS Aurora PostgreSQL RDS works as the HA database?
AndrewSakowicz
