ArcGIS Monitor 2023.1 ETA and Fixes
2069
6
04-20-2023 08:00 AM
SteveMcCarthy
Do we have an ETA on ArcGIS Monitor 2023.1?  Is there a list of what will be fixed in ArcGIS Monitor 2023.1?
I was wondering if there will be more than a fix for BUG-000155947 in 2023.1?
BUG-000155947:
Bug fixes are addressed in upcoming releases or general patches, or they may be addressed as ad-hoc fixes. Enhancement requests are implemented in upcoming releases.
Updates have been made to the following defect which you are associated with:
BUG-000155947 - The ArcGIS Monitor 2023 installer fails when the designated service account password contains special characters.
Status: Fixed (Learn More)
Version Fixed:  2023.1
Alternate Solution:
Avoid using any special characters in the program's designated service account to avoid error messages. Examples of special characters include:
Tags (3)
DerekLaw
Esri Esteemed Contributor
Hi @SteveMcCarthy,
The release is scheduled for end of April/early May timeframe.
This information will be shared when we release. We don't share earlier because while items are planned, they may still change before final release. We will have a blog announcement with this info when 2023.1 releases.
Hope this helps,
DerekLaw
Hi @SteveMcCarthy,
Hope this helps,
tigerwoulds
@DerekLaw Are we going to be able to upgrade from 2023.0 to 2023.1? Or is a fresh install required?
DerekLaw
Hi @tigerwoulds
Moving from Monitor 2023.0 to 2023.1 will be an in-place upgrade. You will just run the Monitor 2023.1 installer on a machine with Monitor 2023.0 and it will upgrade.
Hope this helps,
DuongHB
We met strange issue:
- At 2023.0: can install AM with the special characters
- At 2023.1: can not install AM with the special characters
Very different with announcement here: https://support.esri.com/en-us/patches-updates/2023/arcgis-monitor-2023-1-release-notes-8107
Issues addressed
  • BUG-000155947: Fixed an issue causing installation to fail on Windows when the service account password included certain special characters
DerekLaw
Hi @DuongHB,
Can you please contact Esri Tech Support so they can investigate your issue further? As far as we're aware BUG-000155947 was fixed.
Providing Tech Support with detailed steps to reproduce will help us look into your issue.
Thanks.
DuongHB
Thanks Derek,
Recently 2023.2 fixed the issue.
