AGM 2024: Register Component Azure SQL server Version not supported
618
11-14-2024 07:21 AM
DavidLovesArcGIS
We created a standard Azure SQL server and Azure SQL database. We installed ArcGIS Monitor agent on machine that can access the SQL server/database. If we try to register SQL server component in ArcGIS Monitor, then we get this error:
Version not supported. Found 12.0.2000. Expected minimum 13.0.0
We have tried to go to a newer Azure SQL server/database version, but there is no newer version in Azure? Azure SQL server/database says it's using 12.0.2000, but it always runs on latest version of SQL Server (https://learn.microsoft.com/en-us/answers/questions/929704/which-version-of-sql-server-is-currnetly-...). So we feel this is a bug in ArcGIS Monitor, that it can't connect to latest Azure SQL Server.
Does anyone know how to fix this error, or can ESRI help to fix it if it's a bug?
StevenBeothy
Hello David
Yes this is a known issue and the ArcGIS Monitor team has been made aware of the problem
Not sure if this issue will be addressed in the next patch but fingers crossed!
StevenBeothy
Hello David
