LightSectorsL needed for the Generate Light Sectors tool
470
01-20-2025 06:07 AM
RubenCox
When executing the Generate Lights Sector tool (with usable LIGHTS data in AidsToNavigationP) the error
Failed to open table LightSectorsL!
 is thrown.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/maritime/generate-light-sector.htm
and https://pro.arcgis.com/en/pro-app/latest/tool-reference/maritime/generate-light-sector.htm
describe that such table should be present in the feature dataset so the tool can write to it.
However, there does not seem to be such feature class imported in the workspace when using any of the XML Workspace Documents provided in the product files for 3.4. Manually adding one in the workspace does not seem to resolve the issue (possibly because the schema is not correct when adding without any additional fields).
Thus, I'm looking for the schema for this feature class so it can be added manually, OR an example feature class that can be copied OR a XML Workspace Document that would include LightSectorsL.
Thank you!
PaulinaKarkauskaite
Hello @RubenCox , which XML workspace document from product files have you imported? The Generate Light Sector tool requires the paper chart schema. The template for the Paper Chart schema is located at <installation location>\ArcGIS Maritime\Product Files\<version>\Charting\Schema.
Online documentation: https://pro.arcgis.com/en/pro-app/latest/help/production/maritime/create-a-maritime-database.htm#ESR...
Paulina
PaulinaKarkauskaite
Paulina
