How to Generates vector tiles from a S-57 map ?
1293
07-06-2022 07:47 PM
songqin
1. I have finished  import S-57 files into a geodatabase and added the Maritime.lyrx
or
2. Create a tile package using Maritime Chart Service( run the mcstpk.exe )
CraigTGreene
You can use either method. If you use the maritime chart service and the mcstpk.exe, you do not need to import the S-57 to geodatabase. It might help to know a little bit about your intended use of the tile package to suggest one method over the other.
jiaqili1
Hi, I have the same issue.
Do you find the solution about this question?
