ArcGIS Pro 3.0 for Maritime
773
5
11-03-2023 01:00 AM
TonyDao
Hi All,
I am using ArcGIS Pro 3.0 for ENC creating, when I select a feature for attribute editing, could not see the Maritime Attribute.
Anybody can help on this?
Paulakark
Hello @TonyDao
Was ArcGIS Pro installed for all users on the machine or for current user only?
Do you have access to the C:\Program Files\ArcGIS\Pro\Resources\Maritime\ directory?
Are you using folder redirection/DFS namespace in your setup?
Thank you,
Paulina
ChrisUnderwood
Hello @TonyDao , does the file that the error message references, C:\Program Files\ArcGIS\Pro\Resources\Maritime\ENC_Product.xml, exist on the system you are using ?
TonyDao
Hello Chris,
Nope, by default when Arcgis Pro was installed, the file doesn't exist.
TonyDao
Do you have that file on version 3.0? Can you share that to me?
Paulakark
Hello @TonyDao
Thank you,
Paulina
TonyDao
Many thanks Paula! I got problem solved
