Issue with default layers in Blueprints sample map
834
12-13-2024 08:46 AM
Games4SciAndEng
Hello,
I am trying to get the SanFrancisco_Bldgs Arc GIS3DObject Scene Layer and TotPopTile2 Arc GISImage Layer with Properties nodes to display when I run the Blueprints sample level for the ArcGIS Maps SDK v1.7 for Unreal 5.4. However, I am getting the following errors that cause the layers not to display:
LogTemp: Error: ArcGISLayer status=Error name='' message='Authentication configuration required.' additional-message='Authentication configuration required for https://tiles.arcgis.com/tiles/z2tnIkrLQ2BRzr6P/arcgis/rest/services/SanFrancisco_Bldgs/SceneServer'
LogTemp: Error: ArcGISLayer status=Error name='MDF-HDF Total Population' message='Authentication configuration required.' additional-message='Authentication configuration required for https://tiles.arcgis.com/tiles/oZfKvdlWHN1MwS48/arcgis/rest/services/TotPopTile2/MapServer'
I was wondering what I can do to fix this? Thank you!
AShahbaz
This sounds like a missing or invalid API key. Can you confirm that you have added a working API key in the project settings (under Plugins > ArcGIS Maps SDK) or the map actor or the map creator UI?
