Unity3D ArcGIS Plugin - Object Colors?
2008
09-05-2022 06:11 AM
IngmarWittmann
is there an easy way to get the colors of the objects. In the attached picture you see the colored model in the map viewer, but in unity the same model has no colors.
Please help, i need the colors in Unity. Textures are displayed normaly.
Thank you!
Greets
Ingmar
PS: and the correct model names would be nice too.
IngmarWittmann
With the new Plugin Version, colors are displayed! Thank you!
WH1981
Hello, I also had that problem. But only when i direct drag assets in the Hierarchy window. Before i dragged it i go to the Inspector and change there the Normals to Calculate and then i got the colors.
The problem also can be that you don't have the latest version of the ArcGIS SDK plugin or that the 3D Object Scene layer from ArcGIS is a older version. Share it again as Web Layer and use ArcGIS Pro 3.0
coryeicher
Hi @IngmarWittmann
Another possible explanation: the ArcGIS Scene Viewer can render symbology/colors which the ArcGIS Unity SDK cannot.
What worked for me to update colors in Unity:
1) Update the multi-patch symbology for my 3D object(s). I used ArcGIS Pro to do this.
2) Republish the web layer to  your portal (creating new/updated "Scene Layer - 3D Object")
-Cory
CORY EICHER
www.eichcorp.com
[email protected]
IngmarWittmann
