Custom elevation layer
965
10-18-2022 01:52 AM
ChristofferLindellBolin
Hi, I have been trying to create a custom elevation layer in ArcGIS Pro that I have shared to my Enterprise server. I have been using this dataset to create the elevation layer https://visibleearth.nasa.gov/images/73934/topography. The problem is that ArcGIS Pro does not seem to export vertical exageration settings, which means that there will be no height differences when I later reference the layer in Unity. I have neither found a way in the Unity API to change this attribute. Anyone know any workaround?
The reason why I would like to be able to create my own elevation layer is due to that I want an on premise solution streaming data "offline" and I don't seem to be able to download the entire elevation layer offline from ArcGIS Pro due to restrictions.
