Hi,I have flowed the operation of the document for making the sample scene!But it is same like not work.
The layer data was not been rendered over the base map. Anyone can help me to fix this problem?Thanks
Did you add this as a 3d object scene layer https://tiles.arcgis.com/tiles/z2tnIkrLQ2BRzr6P/arcgis/rest/services/SanFrancisco_Bldgs/SceneServer?
yes,but the layer data still not been rendered ! although,it is so strange that it is been rendered when i use the C# API for creating a arcgis map!
Sorry I commented the wrong link I ment this one https://tiles.arcgis.com/tiles/z2tnIkrLQ2BRzr6P/arcgis/rest/services/Buildings_NewYork_v18/SceneServ...
I am having the same problem, the layers that I added by following the tutorial steps do not show up when I run the game. I do not see those layers in the Scene view or the game view. I have set up the API key and am seeing the full set of basemaps so I think that has been done properly.
