Layer data was not been rendered over the base map.
2501
12-08-2022 01:46 AM
虎哥小
Hi,I have flowed the operation of the document for making the sample scene!But it is same like not work.
The layer data was not been rendered over the base map. Anyone can help me to fix this problem?Thanks
虎哥小
Matt_Nelson
Esri Alum
虎哥小
yes,but the layer data  still not been rendered ! although,it is so strange that it is been rendered when i  use the C# API for creating a arcgis map!
Matt_Nelson
Esri Alum
BillWinston
Hello,
I am having the same problem, the layers that I added by following the tutorial steps do not show up when I run the game.  I do not see those layers in the Scene view or the game view.  I have set up the API key and am seeing the full set of basemaps so I think that has been done properly.
