Finding highest altitude within extents
903
03-09-2023 03:28 AM
Thomas-F
I'm interested in being able to determine the highest altitude on an elevated local map within the set extents.
My current approach would be to create a box collider above the map and move it up / down to find the highest point at which it intersects with the map mesh. I can use a binary search style approach to find this in a reasonably low number of intersection checks. The problem with this approach is that it doesn't give an exact result, but rather an approximation depending on a precision threshold which controls when to stop doing intersection checks and accept the result.
Is there any API available through the SDK that might help me in calculating this?
