Doubt to access latitude and logintude
1536
12-17-2023 09:06 PM
Manoj081498
Hi Everyone
I am new to unity and working on ArcGIS Map SDK
As we know that in ArcGIS camera Gameobject we have ArcGIS Location which has longitude and latitude.
how we can access those into my game window.
Thank You,
Manoj
Tags (1)
and1
by Esri Contributor
If you just want to display the current ArcGIS Camera position in terms of long and lat, you could check the ArcGIS Location Component that is attached to the ArcGIS Camera gameobject.
You could also get it displayed in the game window by passing those info to 2D UI texts. You should be able to get the lat and long values by requesting the position. (check ArcGISLocationComponent.cs in Assets/ArcGISMapsSDK/SDK/Components/). It will give you the X, Y, and Z values of the ArcGIS Point, depending on the spatial reference.
and1
by Esri Contributor
Hi, you can reference the ArcGISCamera API for accessing those.
Manoj081498
Can you explain it little bit more.?
and1
by Esri Contributor
Manoj081498
I got it, Thank you
But the ArcGIS Location is the location of camera. Is there any way to get the location of cursor where we point mouse pointer in the map
