Error when syncing into Illustrator
5072
9
11-02-2023 03:13 AM
AdamBushnell
Hi just upgraded to the new 2024 Illustrator and the 3.6.0 plugin and am now getting the following error when trying to sync a map into illustrator. Any ideas?
Many thanks
3 Solutions
Anna_Breton
Hi @AdamBushnell, we have another possible solution for you to try. Can you try the following steps:
  1. Close Illustrator
  2. Locate the config.json from C:\Users<username>\AppData\Roaming\m4cc\config
  3. Open the config.json above in a text editor
  4. Change the "outputDirectory" value to a local folder (e.g. "outputDirectory": "C:/Users//Documents/") and save the file.
  5. Restart Illustrator and sync a mapboard.
Let me know how this works for you.
- Anna
AdamBushnell
Thank you so much! This works great
Anna_Breton
This issue has been resolved and is in the 3.7 version of ArcGIS Maps for Adobe Creative Could. Please upgrade to the latest version of the extension if you are running into this issue. Thanks for your patience!
Anna_Breton
Hi @AdamBushnell ,
Can you try uninstalling the Maps for Adobe extension and then reinstalling it? This may be related to the order in which you updated your software. Let me know if that fixes your issue!
-Anna
AdamBushnell
Hi Anna,
I'm afriad that unstalling and reinstalling the software hasn't fixed the issue. It's strange as it was working fine before the recent illustrator/arcgis extension update.
Anna_Breton
Hey there @AdamBushnell
After a bit more digging, it looks like the issue you're seeing may be related to your download folder naming convention. How fun!
If we look at the screenshot you shared above, you'll notice a "%2c" after OneDrive - in your download folder URL. This indicates that there may be a comma in your OneDrive folder name...and commas (and other special characters) can break things 😀
If you can change the name of your OneDrive folder to not contain any special characters, such as commas, your issue should be resolved.
To change the name of your folder you can try right clicking your OneDrive folder location, go to properties, and you can edit the name of your folder there. If you complete those steps but don't have access to make name edits, you may have to disconnect your OneDrive account. After you unlink your account, then you can go to properties and edit the name of the folder, and then re-link your OneDrive.
Here are some steps to help with that process if needed
If we can get rid of that comma, you should be able to sync maps with no issues.
Let me know if this helps!
-Anna
AdamBushnell
Hi Anna,
Thanks for all the help so far
I'm afraid that option won't work - my organisation's oneDrive location is pre-named and can't be changed. From a bit of goggling it seems that Microsoft will use the naming convention for all enterprise clients with that comma.
Nothing has changed apart from the illustrator 2024 and arcgis extension 3.6 upgrade.
Anna_Breton
- Anna
AdamBushnell
ElisabethNadin
I just tried this an it's not working for me. I have set up the configuration as you recommended, I have the new version of ArcGISMapsforAdobeCC ... and still My .ai (2023 OR 2024) won't open and .aix file. Any other ideas for me? thanks.
JanaiSmith
When i try this solution, the plugin no longer works.
Anna_Breton
