Why does my grid always use wgs84 instead of the data frame projection?
2911
08-13-2014 01:43 AM
ChrisHills
The coordinate system of my data frame is set to British National Grid, however when I try to add a grid (graticule) it is always projected using WGS84. How can I add a grid using the correct projection?
ArcGIS version is 10.2.1.3497.
DanPatterson_Retired
I suspect that the data are in wgs84, did you follow the steps as outlined here
ChrisHills
Thanks for the pointer Dan, the answer was to use measured projection instead of graticule.
