Splitting by aggregating other data
4151
05-31-2016 02:09 PM
HectorBorro1
Hi there,
I have some service areas that I need to split down into other areas. Initially, it sounds straight forward right?
The problem arises when I need to split these areas to have approximately the same population  in each regardless of area size...
I have one layer with the population by Zip-code (GREEN) and another with the areas I need to split (RED)
So I need to create 2,3, or 4 sub areas RED with approximately the same population in them.
Any help would be appreciated.
Cheers!
H
HectorBorro1
PS. I'm using ArcGis Pro ver. 1.2
FC_Basson
There is a Districting Add-on Districting for ArcGIS | Overview  for earlier versions
HectorBorro1
Many thanks FC Basson, looks like the right kind of toolbox I need. I'll give it a try and let you know how it goes
