Suggestion on Updating Administrative Boundry of the Philippines
483
09-17-2025 06:03 PM
KalebPunzalan1
The Philippine Statistics Authority (PSA) published the Philippine Standard Geographic Code (PSGC) (Philippine Standard Geographic Code | Philippine Statistics Authority | Republic of the Philippines), and I found it on GitHub (GitHub - altcoder/philippines-psgc-shapefiles: High resolution Philippine PSGC administrative bounda.... Can the ESRI team update this based on the latest administrative boundary? One example is attached, showing that the administrative boundary is different from the actual one published by PSA in their PSGC.
KenBuja
MVP Esteemed Contributor
It's probably better to submit your feedback through the Basemap feedback map.
George_Thompson
Esri Notable Contributor
If you have feedback, you can enter it here: https://www.arcgis.com/home/item.html?id=ebdfa4146680410bb952c7d532ea5407
--- George T.
KenBuja
