Zoom to Point...
1186
11-09-2011 08:50 AM
GISAdmin1
Is this still the method to zoom to a point using the ESRI Javascript API?
 var PointExtent = new esri.geometry.Extent();
 PointExtent.xmin = selectedAddress.geometry.x - .001;
 PointExtent.ymin = selectedAddress.geometry.y - .001;
 PointExtent.xmax = selectedAddress.geometry.x + .001;
 PointExtent.ymax = selectedAddress.geometry.y + .001;
 map.setExtent(PointExtent);
Or, is there a new method?
Thanks in advance,
M
JeffPace
Thanks in advance,
M
Since its a point, I prefer
map.centerAndZoom(selectedAddress.geometry,19); // 19 or whatever zoom scale you prefer.
Mete_ErcanPakdil1
Jeff, I don't agree with you since it zooms more than current every time when it is called by user.
JeffPace
Well since by default a point does not have an extent, you have to assume one.  If you want to stay at the current, you are not zooming, you are panning, in which case just call map.centerAt(pt).
derekswingley1
Another option is to calculate a new extent from the map's current extent and use that to zoom. It's similar to the original code that was posted in this thread but instead of using a hard coded value, the value used to pad the point is calculated on the fly. Something like this:
var tolerance = 5,
    pxWidth = map.extent.getWidth() / map.width,
    padding = tolerance * pxWidth,
    newExtent = new esri.geometry.Extent({
      'xmin': evt.mapPoint.x - padding,
      'ymin': evt.mapPoint.y - padding,
      'xmax': evt.mapPoint.x + padding,
      'ymax': evt.mapPoint.y + padding,
      'spatialReference': evt.mapPoint.spatialReference
map.setExtent(newExtent);
