wkid from wkt
1497
04-16-2013 12:26 AM
CristinaJacome
Hello
If I create spatialreference with the WKT:
var sr = new esri.SpatialReference('GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",
  SPHEROID["WGS_1984",6378137.0,298.257223563]],
  PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]'
How can I know the WKID??
sr.wkid is null.
sameerpuppal
for custom spatial reference, only WKT will be available and WKID is null. you can also confirm the same by checking the REST end point of your service. if it shows WKT then it is custom spatial reference.
You can check list to get closest or matching WKID :
http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html?project.html
Best luck
Regards,
Sameer Puppal
GIS Developer.
Mahindra Satyam, India.
